....or any other cluster for that matter. Now to my question. What parts would I need to put in a 9c1 intrument cluster with a tach and other guages (oil, volts, water temp) in a 92 civilian caprice? I saw a 91-92 caprice in the junkyard and it had a cluster with a tach and I wanted to be able to see whats going on with my engine as i drive.
I believe your gonna need the cluster and as much wiring as you can get from the donor caprice ,plus your gonna need the dash panel from the donor as well because the grampa style dash has the idiot lights and does not fit with the 9c1 cluster.Good luck ,LaTerZ...
