Hi,
Can I install a sway bar from a 9C1 car on spohn lower control arms?
Sure. The stock arm (which is the same as the stock SS arm in case you thought the 9C1 might be different) works w/ the stock LCA's, so any upgraded LCA will be able to accomodate it as well. It's when you use a stiffer/longer/sturdier sway bar in conjunction w/ the stock LCA's where you begin having problems.
Thanks,
I was asking because I have a 1987 Cadillac Brougham. I don't have a sway bar at the back. So I bought some used Spohn UCA and LCA and I would like to install a sway bar but not one that would be making the ride too harsh and that's why I decided on maybe using the pair that is from a car with a 9C1 package. I wasn't sure if aftermarket LCA work with regular sway bars
