i replaced icm. water pump. spark plugs...wires...radiator....hoses. but not the optispark......do you think that may be the problem??? or is it the ecu??
Are you getting spark at the coil? Are you getting spark at the plugs? Are you getting 41-47psi fuel pressure with the key on and engine off? You can throw parts at the problem until you're out of money. Do a full diagnosis first.
See the first sticky in this section. Does anyone read this stuff?
