Hi!
Clutch is engaging and disengaging... I just replaced every component in my a/c system ( comp, cond, evap, hoses and sensors and my **** is messed up.
I service low and high side with correct Freon a mint and low side goes to like 70 and high rises to like 450 and I get scared and shut it off.
condenser not getting hot, drier isn’t getting cold. I cleaned the orifice tube out and noticed a few metal shavings but not bad like what you see online....
moral of my spiel is I service it and I’m basically getting an over pressure in my low side when I service with correct amount, and my high side goes through the roof.
At work I have a robinair servicing cart (use on helicopters) so I know I’m adding the correct amount of Freon.
I add 28 oz (1lb 12 oz) 6 oz of oil for my first charge of the system.
thoughts? Ideas? Maybe it’s compressor? Or filter drier is toast?
