Anybody know of a source to get these clips? one of mine broke off the pillar and would like to replace
Already contacted him, didn't have one readily available but because of the odd shape, shipping might be pricey.
If it popped off in the pillar, you can reweld it to the trim piece with a soldering iron. You may have to add some material, or at least reshape the material that is there. You asked me for a gray pillar. I said that I only had other colors. The gray ones are hard to find.
I may have a broken pillar in my storage.
LMK if you're still needing this clip and I can look into it tonight when I get home.
OP if you can't repair yours as Fred notes (JB Weld is also a way to secure the clip) you can use any color A pillar trim and paint it with SEM. I used their primer then the grey spray paint
That is what I did when I got a A pillar from Fred when I added a pillar gauge as I did not want to drill my stock Grey one incase I ever wanted to delete the oil pressure gauge I installed
