1 - 14 of 14 Posts
Ok, I have searched but can not find anything. Is there somewhere on here that lists all of the abbreviations used on the forum. RMW, I think I figured out that I have one. I assume it is Road Master Wagon. In fact, I think I used it a couple times, I hope I was right on its meaning. Thanks guys.cwm3
FWIW IDK. IIRC you're right. I got GWS, but haven't grokked SMH yet.
I'm sure you'll get legit replies now that I've provided the official 'thread assing' one. ;)
:) For What Its Worth, I Dont Know...
I think I got all the "web acronyms" what I struggle with is all the Imapala, Caprice, Roadmaster acronyms used on the forum...
Thanks.
Such as:
WB4- RPO code for factory wood delete
DCM- Dark Cherry Metallic
MAB- Medium Adriatic Blue
LAB- Light Adriatic Blue
DGGM- Dark Green Grey Metallic
9C1- Police package Caprice
I'm past my 'pass out' time, so thinking of anymore shall be left to others. :)
Some I know:
OCC - Oldsmobile Custom Cruiser
LDM - Light Driftwood Metallic
DGGM - Dark Green Gray Metallic
MAB - Medium Adriatic Blue
RMS - Roadmaster Sedan
RMW - Roadmaster Wagon
L03 - 305 V8 / TBI
L05 - 350 V8 / TBI
LT1 - 350 V8 / SFI / Hi Performance
L99 - 263 V8 / SFI
LAB - Light Adriatic Blue
DCM - Dark Cherry Metaillic
OBD-I - On Board Diagnostics PCM v.1 (Pre-1996)
OBD-II - On Board Diagnostics PCM v.2 (1996-)
plagiarized from Qalo's impala ss handbook:
4L60E – the transmission model that was stock for the LT1 equipped B-Bodies.
4L80E – a replacement transmission for the LT1 that is more heavy duty and handle more
horsepower.
Air Box – in case you didn’t know, the air filter casing behind the driver’s side
AIR FORCE ONE – an alteration for the RAISS intake set up. A metal wind deflector.
B- Body – Caprices, Impalas, Roadmasters
BBB – Nickname acronym for Black paint color, Some translations are “Big, Black,
Beautiful”, “Bold, Black , Beautiful”, “Big, Black, Bitch”. The actual color name is
Standard Onyx Black or SOB.
BLINK BLINKS – sequential brake lights
BMR – Manufacturer of control arms.
CAT EYE GRILL – a type of aftermarket grill, sold from Socal Street Trends
LTZ – a certain package for the Caprice.
CEL – Check engine Light
D- Body – Cadillacs
DCM – Paint Color, Dark Cherry Metallic
DGGM- Paint Color, Dark Green Gray Metallic
DTC - Diagnostic Trouble Code
ECM – Electronic Control Module or Engine Control Module
EGR – Exhaust Gas Recirculation
FB – First Base, the rectangular baffle between the home plate (HP) and the air box.
F-Body – Camaros, Firebirds, etc.
HA – Herb Adams, refers to a maker of an aftermarket sway bar.
HO – refers to a maker of an aftermarket sway bar.
HP – Home plate, the home plate shaped baffle on the engine.
HP – horse power
HPP3 – Hypertech Power Programmer III
IMHO – In my honest opinion
IMO – In my opinion
LCA – Lower Control Arms
LED – Light Emitting Diodes, refers to the warning lights in your instrument cluster
LS1 – the GM replacement of the LT1, found in new Firebirds, Camaros, Corvettes.
LT1 – Your engine man.
LT4 – Engine Upgrade. New cam, so on and so on.
LT5 – Engine upgrade, Tim Allen’s SS has one.
MAF – Mass Air Flow Sensor
MIL - Malfunction Indicator Lamp
O2 - Oxygen
OBD - On Board Diagnostics
OBD II - On Board Diagnostics, Generation 2
OEM - Original Equipment Manufacturer
PCM – Powertrain Control Module
PCV – Positive Crankcase Ventilation valve
PITA – Pain in the ass
RBT – Red Bow Tie
SOB – Standard Onyx Black, see BBB
T56 – Type of transmission, replaces the 4L60E, for the manual shift conversion.
T84 – an aftermarket headlight kit that shines a lot better than stock.
TB – Throttle Body
TEFLON TAPE – white tape used to seal threads in order for no fluid leakage. Found in plumbing
section of stores.
WIG WAGS – police style alternating headlights.
WOT – Wide Open Throttle
WX3- Code for Super Sports on label in trunk.
BFH = Big F***ing Hammer
wtf is the "GWS" people always use in here though? Get well soon?
Sweet guys thanks. Looks like most of my confusion was around abbreviations of color... This list will be nice to have.
HELLO!?! 1A2!?
(The most important code....)
I prefer OCC to CCW. As a result of being on a few gun boards I automaticly assume someone is talking about their carry gun or permit...
Dont forget RTFM...
ETA: www.acronymfinder.com Comes in handy on occasion.
LCA = Lower Control Arm
1 - 14 of 14 Posts
