I do not know if they are made in stainless, but the 89 and 90 B-body lines will fit.
Awesome! thanks Fred, I know of a few places that may be able to duplicate them in stainless as long as they have a current design to work with on file. I'll let you guys know what I find out for anyone else interested in doing stainless prebent lines with ABS delete.I do not know if they are made in stainless, but the 89 and 90 B-body lines will fit.
I would be very interested in what you find out. There are other threads where this was brought up before but can't remember if anything was ever found. I may search for it later.I'll let you guys know what I find out for anyone else interested in doing stainless prebent lines with ABS delete.
There is already a PV just below the MC and would assume if the Early lines fit our cars, then they must already have a PV in the same area too.Great timing. I was actually driving around today getting quotes to bend some lines for this purpose. That would be great if there was a pre-made solution.
I was going to put a pro portioning valve on the rear lines, but I wonder if I could fit an after market combination/ proportioning valve in with the '89/'90 lines?
I guess It depends where the '89/'90 lines splist the front brake lines...
I'd like the adjustability, esp when dropping ABS and eventually upgrading calipers. I'm hoping to stop and turn in this big tank!There is already a PV...Not sure why you would want to add another...
...why not consider the CPP Master Cylinder? Its at least a different option for you and are just about $150... Mike installed one...
http://www.impalassforum.com/vBulletin/showthread.php?t=257194&highlight=CPP+Master+Cylinder&page=2
I guess someone has to do it and see.I'd like the adjustability, esp when dropping ABS and eventually upgrading calipers. I'm hoping to stop and turn in this big tank!
Thanks for the link. That does look like a suitable option as well.
If I haven't heard back on 89/90 lines in the next few weeks I may be the Guinea Pig...
It seems like Fred was was pretty sure these would fit, maybe he could provide more info on the fittings and if they are the same. If not, you may need to be our Guine pig.Inline tube sells the "77-90" kit in stainless as well and they also sell a 94-6 B body kit. I am going to email them and ask them if they could compare the fittings to see if they are the same for the 77-90 kit and the 94-6 B body kit. Then all we need to worry about is if it actually fits (which if they allow returns won't be too big of a deal).
I'm willing to bet they could make the 77-90 lines with the same fittings as the 94-6 but it may cost extra.
You guys are way over thinking this.
All you need is to get the stock line set and modify that.You use the stock front line going to the ABS from the MC and use a inverted flare T on top of the frame rail and connect the L&R lines and front line from MC together.
The Rear you just rebend and flare it for a union where the frame turns down unde the firewall.
