2012 I bought this car...light been on ever since....any body know what's up with this....got knew brake system..spent 1200 dollars on brakes bout a year ago...light still on
Bosch 2U system is a separate system from the PCM. You need a scanner or software that can talk to it. Most do not. There are 13 different codes.
Bosch 2U ABS Systems, Bill Williams, Brake & Front End, June 2002
If you are going to pay for a brake scan make sure you will not have to pay if they can not read it. Between 91-96 the system communication changed several times and not all "PRO" systems are programmed to read the ABS correctly. The gum chewer will then tell you that since he can not read it it should be replaced. It might be true but probably not .
