·When starting engine, ABS Warning Light is off. By the time I reach the driveway, light goes on and stays on until shutoff.
I've already lengthened the evap. drip hose to avoid water drip on that ABS sensor.
The system keeps track of the MPH on each wheel. A scan tool (GM) indicates the correct MPH for both front wheels and 0 MPH for both rear wheels.
I'm trying to determine which sensor(s) are causing the problem or can it be the rear end reluctor gear. (Aftermarked 3.73 from Motive)
Thanks,
slick50
96DCM
Thanks,
slick50
96DCM
