Since I have bought my 94 Roadmaster sedan, I have noticed that the ac compressor clutch always rotates when the AC is on. I know it has been pretty hot this year in Va, but I thought that it would cycle off at least sometimes. It cools fine, but just continues to rotate. Is this bad? Should it cycle on and off sometimes? If so, what do I need to do to fix this?
I have flushed the cooling system, changed the thermostat and coolant temp sensor.
Thanks.
If it is hot enough, it will continue to run. You will probably have to wait until the weather cools off before you can determine any malfunction.
I thought my R-134a conversion on my 92 had an issue because it ran constant.. Nope.. It will cycle when driving at a higher RPM and cycle alot when its cool outside. (Which never happens here)
If the outlet temp is cool and the Low pressure AC lines are not freezing over solid, It should be fine.
