I don’t think vacuuming should remove any oil from the compressor just removes all moisture from the systemYou can evacuate from just the low side.
The one wild card is oil .
A recovery machine will separate any oil that comes out with freon so you can put back the correct amount ,,, ASSuming you had the correct amount before !
Slow bleed down ( if anyone still does that) you dont lose measurable oil but you are still assuming what is in
