Accusump Pre-Oiler and Oil Pressure Saftey
I got a bunch of question on my exhaust thread as well as PM's about my accusump.
So here is some accusump info.
If you have not heard of the accusump
it hold a reserve of filtered and pressurized oil
incase of oil psi drop out the valve opens ans keeps things going for about 45 seconds.
It also works as a pre oiler when you turn the key forward.
theoretically I never have to start the motor with out oil pressure on the main bearings!
http://www.accusump.com/
tech info at
http://www.accusump.com/accusump_tech.html
this is the Accusump, nice distro block, electric pressure controller / check valve
and the Gen1 lines that sucked.
Silver accusumps look the best to me but that is the older Gen1
Gen2 Accusumps are all Blue
look close there is a oxy cut on both sides of the bumper
with just a little bit of a cut out the accusump just slides right in.
here it is fully installed
you can see it thru the holes I cut in the bumper to help offset the weight of the unit.
I hate having clutter in the engine bay.
This is out of the way and clean.
once the bumper cover goes on...
it just dissapears.
I almost need a electric sender so I can check the accusumps nitrogen pressure...
The PLUMBING
pictured next is these are the gen.2 hoses
Eaton weather head 3000PSI 350F lines
Double braided tripple rubber sleaved hose
with crimped fittings aka not going anywere aka never leaking
the PermaCool 4 port spin on adapter take a PH8A aka Napa 1515 aka Mobil1 M1-301
IMHO the nicest and most available filter on the planet!
Not shown in thes older picture
I moved my oil pressure and oil temp to this location
cause the new headers were all up in the sender port in the block
the 4 port permacool base feeds my in out to the filter with a fat 1/2 NPT ports
in / out from the accusump and send to cooler that returns to the engine
and a spare port for gauge senders!
It's cheap and made in AMERICA!
Perma-Cool 1791 - Perma-Cool Remote Oil Filter Brackets
tech info at
it just dissapears.
The PLUMBING
