1 - 12 of 12 Posts
hello fellas i have 20'' boyds with adapters and the rears rub in the top of the inner molding only on the left side. The tires are 275 40 20 ,if i were to go to a smaller size would the rubbing go away.Its a 96 impala with the wider rear
By 'left' side, I assume you're meaning driver side. That's strange, as usually it's the passenger side that's the 'tight' side on these cars. Hmmmmm.
-Mike
Damn that looks all wrong,tires are way to big.The body needs to be shifted I would concider smaller adapters..
Smaller tires..
smaller adapters..
body shift..
lower..
Then it will look good..
1 - 12 of 12 Posts
