·Im in the works of installing bags in my 91 caprice and have gotten to the point of setting up the rear bags. I've been emailing people here trying to get different ideas, I want to lay with 18's, all the notching that has to be done is done! but what I find is that using the factory trailing arms, when the rear end comes up it starts to roll forward because the upper arms are shorter then the lower. building a new 4-link setup was not in my plan. So want im asking is how do other people setup the brackets for the upper and lower bag mounts. What i did was make a flat plate on the upper spring mounts and put a small bracket on the axle but cuz the rear end rolls the bag twists alot. Please posts pictures if you have them
Oh, and by the way, yes the trunk floor is cut out!
