·Hi folks,
I finally got my bags for the Imp. Shockwaves for the front to replace the Penske/Carrera coil-overs (already sold) and regular Firestone 255 bags for the rear to replace the ST springs. Now to the problem, I dialed the rear in that "low" is when the axle solidly rests on the bump stops. Means, my bag brackets are only about 2" long each with fully deflated bags. Now, if I lift the car off ground the shocks are too long and would not lift the axle off ground without pulling the bags apart (I miss about 2 " on top of the fully expanded position). What do you guys use to keep the bags alive when you lift the car off ground ? Straps, or is something wrong with my setup ?
BTW, had to remove that stupid fenderwell trim so that the rear slips over the 20x10 rims. Looks a lot cleaner now, altough some sheet metal work and paint was in order. Having the rear lips flared out a bit and smoothed looks incredibly cool.
With 4way control, car rides great. First tiem in my life that I can use Public car parks !
heinz, turboed, bagged, and cruizin' low
