1 - 20 of 37 Posts
Have any of you installed a viper alarm,maybe 5701 or other with remote start on your own car?
The shop near me wants 499.00 installed for a python something!
They have been around a while but i dont know if its worth all that or something I can do.
If you have any hints,tips?
I've installed alot of them over the years.
Just need to take your time is all! if you've never done it I doubt you'll do it in a day. But you do learn alot. There are also tons of charts to help with the wire coding to make it a snap.
are the charts included with the alarm or I have to research them?
mostly likely not, tell me what year and the info for your car I'll post them all right here for you
Ive been debating installing a viper 5901 in my car as well.
95 caprice 4.3 v8 power windows,locks,power trunk
anything else you need to know
And thanks for the help!
This is your cars wiring for a 1995 Caprice:
Constant 12V+--------------- Red ---------------Ignition Switch Harness
Starter ---------------Yellow--------------- Ignition Switch Harness
Ignition ---------------Pink ---------------Ignition Switch Harness
Ignition 2 ---------------Brown--------------- Ignition Switch Harness
Accessory ---------------Orange ---------------Ignition Switch Harness
Tach ---------------White Or Purple/White (-) ---------------At Coil V8 or Multi Coil V6
Neutral Safety Wire ---------------Orange/Black --------------- Gear Select Switch
Brake Switch ---------------White ---------------Brake Switch
Trunk Release--------------- Black
Trunk Pin ---------------Dark Green (-) --------------- Driver's Kick Panel
Parking Lights--------------- Brown --------------- Light Switch
Head Lamp--------------- Yellow--------------- Light Switch
Door Trigger--------------- Blue/White (-)--------------- Driver's Side Floor Lamp
Door Lock ---------------Light Blue --------------- Driver's Kick Panel
Door Unlock ---------------White --------------- Positive Trigger
Horn Wire ---------------Black (-)--------------- Steering Column
Windows Up--------------- LF=Dark Blue, RF=Light Blue,
Windows Down
i installed a commando fm870 2 way remote start and alarm on my 95 caprice a couple months ago........my first install....all you have to do is take your time....all the wires make it look hard but it's not that bad.....may take a couple days....it's way better than payin somebody else $400.....good luck
Now thats alot of info
Thanks for all your help
Im gonna give it a try I will keep you guys posted!
take ur time and have fun with it. You'll learn what makes your car tick.
if you need help just ask.
I also want to install an alarm system too! I've never done this before either but have basic knowledge of electrical systems.... hoping i can do this in a day! Just keyless and alarm nothing fancy.
I want to go with this and mod the flip key and put an ss key in it.
http://cgi.ebay.com/ebaymotors/FLIP-KEY-RM-CAR-ALARM-SYSTEM-PATHFINDER-PICK-UP-PULSAR_W0QQcmdZViewItemQQhashZitem3a5456f383QQitemZ250523087747QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_3740wt_939
no offense, but I wouldnt even bother buying that one
What about an alarm that senses the voltage drop, of a door activating the courtesy lights, raised hood or deck lid, activating it's light.
Years ago said alarms were popular for thier simple installation.
Almost no one heads the sound of a veh alarm anyways.
Thats why you get a two way alarm. It lets you know when its going off.
I like mine too! Start the car in the summer let it cool down before gettin in.
Anyone know where you can get a good deal on Vipers??? I paid $350 for my 5701 @ Best buy & installed it myself. I want a more upgraded one for the 91 when I get it together this spring. Want another for "WYTLTNG" too.
Discussion Starter #20
no I never even bought it!
Times are hard and it went way down on my priority list but Im still thinking of it just waiting till cash is right!
1 - 20 of 37 Posts
