·My alignment has worn the inside 1" of my tires down to the belts on both of my front tires. I had an alignment done 2 times in the last 2 years. My last alignment was done by the dealership 6 months ago and I told them at that time that i was getting wear on the inside tread. It seems that they didn't adjust the camber or tow enough. I had my tires rotated first to before going to the dealership to get the alignment. Now in that time period I've worn through 2 more tires on the inside corner.
So, is this something that they can adjust in the next alignment? Do you think that I may have front end parts that are wearing out that will continue to cause this? I had replaced the shocks with Bilsteins about 30-40k miles ago. I had new endlinks and sway bar bushings put in in the last year. I also had a new heavy duty idler arm put in also in the last year or so.
The dealership recommended getting the new tires on first and then re-align the car (or check to see if it needs it).
Has anyone else experienced this problem and resolved it?
