ive read the other stuff but still dont fully known. Im going to have my Sprint springs installed with stock shocks. and was wondering after that do i just need to get a front end alignment and that will fix camber and all that? I'm running 20's and really dont wanna wear out the tires cause there so expensive. and also how often would you rotate the wheels? thanks
Yes, get an alignment. You can only rotate your tired from front to back, not right to left, right? I have directional tires, and I am sure you do, I wish I didn't.
i got sprints and fater a couple of weeks (to let the springs settle) i went and got an alignment back to stock specs. the tech said with no shims it brought i right back to 0 degrees camber.
