Any one have an issue mounting the Altenator running comp cam rollers on aluminum heads. I had to go with a higher valve cover to clear the comp cam rollers. Now the valve covers are not allowing me to mount the altenator because it hits the back of the altenator. I had to grind down the groves on the back of my last altenator two years ago. My ground terminal came loose the other day and I think I my altenator took a dump. I dont want to have to grind down the back of every altenator I put on the car. Any one have any ideas or have the same issue.
Thanks for any suggestions. if you have the issue and figured out a way to mount the altenator with out grinding the back of it. send me some pics
