I I took my alternator apart last weekend...had the case powder coated during the week and am trying to get it back together.
I was very careful and marked all the electrics and sequence of assembly and managed to get all the bearings out and new ones in
PROBLEM IS:
There are three shaft spacers I payed no attention as to what order they came off. I found a publication that says the 6.5 mm thick goes between rotor and drive side bearing....and from observation it looked like the thin one (~6.0 mm) went betwwen the bearing and the cooling fan and the thick one (~100 mm) went between the fan and the pully.
When I reassembled I had well over about 3/8" in and out play of the shaft which can't be right.
If I stick the thickest spacer between the rotor and bearing I loose the in and out play put the pully seems like it will crush into the cooling fan.
Anyone "been there...done that" who can tell me where I have messed up?
I believe you start with the largest, and end up with the smallest last.
