I
4 fuses on my amp blew and then smoke started comming out arent the fuses supposed to protect the amp from frying???
The fuses protect the amp primarily from incoming power surges, faulty supply draw, spikes, etc... If the amp has an internal problem, then the amps may have blown because the amp was pulling in (or perhaps pushing out) too much juice...
What amp was it?
Some are fixable, some are not. It depends if the manufature used "off the shelf" devices, or if they renumber the transistors to a proprietary number.
I
well I took it 2 the store and there going to tell me if they can fix it or not thanks for the replys
