T
Do your subs and speakers use the same amp or do you need different amps?
D
You really should use two for maximum benefit. I have one 300W for my sub and a 4way amp for my speakers. That is, unless you get a very expensive amp. You also wouldn't want to over work one amp.
T
I have a 1000 watt amp should that be fine for the speakers and one 10 in sub
Tony, that amp will probably be too strong for the smaller high frequency speakers, and would even need a pretty healthy sub to handle the power. I'd recommend a 5 channel amp with appx 30-50 watts times four and between 100-300 watts times one for the sub. Most manufacturers of car audio gear have one in the line-up we do Alpine, Rockford, Clarion, MTX and Eclipse and they all offer something anywhere from 300-800 dollars. If you are wanting to use that amp, I'd say to get a four channel amp with somewhere around 75-100 watts times four to match your 1000w amp in volume. You'd need really high quality component speakers to handle that much power though.
T
I have a kenwood 1000 watt amp but thats the peak power its 2 channel so could i hook that to the rear speakers and sub and leave the front speakers alone. My rear speakers can handle 220 watts of power.
u will need to run the sub on low pass and the rear speakers on high pass. if u run them on the same 2 channel amp the sub will play notes too high or the rear speakers will play notes too low. u can get away with a 4 channel amp if u run the rear speakers on the front out puts on high pass, and the sub(s) on the rear outputs on low pass.
good luck.
