1 - 20 of 28 Posts
It's a little tricky! This was addressed sometime back, but I guess that post was lost in the crash, a few months ago. I did mine about a year ago, and I forget the exact details, but the interior panel of the gate has to be removed, then as I remember, the whole housing comes off the gate. It's way too much work for a bulb replacement, so put both in while it's apart!
Remove the small screw that hold the lamp/lens in place. Then you can with a lot of jiggling and cussing slide it out the bottom. Then with child size fingers r&r the bulb and put it all back together.
I just did mine and it was done without removing the interior panel.
There was the fear of breaking it as you say but it didn't happen. I was more worried about the bulb type but that was an easy match as well.
I did the rewinding of the cargo cover the same day, thats hell.
Hey I'm glad you asked this question, because I've been wondering how to do this. I tried to wrestle those lenses out once before but I was afraid I was going to break them. I've had a blown out bulb there for several months. Damn the torpedoes, I'll give it another try and hopefully won't shatter the lenses.
Didn't break mine, its tight but they will come out. I put led's in them so they should never burn out ever again.
It may be intuitively obvious for those with closed minds but its not stupid. Ask away maybe we can help clear the fog.
Basically take the screw out and pry on it to the point that you think it's gonna break and you say "oh **** I'm gonna break it" then they slide right out. Piss poor design, throw some LEDs in there so you won't have to do it again.
1 - 20 of 28 Posts
