The timing of this 'special' is pretty good. I just put a brake controller (for trailers w/electric brakes) in my RM (Tekonsha Envoy works fantastic (inertial type))... and needed a good 20A supply for it and a good 30A supply for 'aux power' to trailer. I sourced both of these on the 'big' post at the 'underhood electrical center'.
And of course the factory post is a little melted/questionable looking. I have a new 'improved' brass post but couln't figure out how to get the old one off quickly... so just cleaned everything up (steel wool) and put it all back together... thinking I would get the improved cables and replace the post then.
So, the new cables have "and 2 gauge copper cable for the alternator and fusebox". What is my factory cable to the fusebox ('underhood electrical center')? Is it 4 gauge (it does look fairly small and did concern me about trying to tap another 50A (20 + 30) from it (especially when it already has melted plastic around the post). Car has factory towing package with bigger alternator; not sure on alternator output... Is this the 200A alternator??
Would I just be best to do the top post type with the 1/0 gauge alternator cable? I am thinking the cable to the 'underhood electrical center' on the top post type is still the 2 gauge (per the web site not indicating otherwise).
Hope my questions can be followed... any suggestions/experience will be appreciated. Also, any experience how to remove the old post (without ripping the 'underhood electrical center' apart) would be appreciated.
Thanks,
Kevin.
