Wiring
This can vary depending on your setup and what kind of harness you use, and if you decide to use some of the stock wiring, fuses, and relays. Lt1swap.com is your friend. Almost everything you need to know, regarding pin outs and wiring, is on that site. You honestly don’t need much from the stock PCM. I kept my A/C and got all the wiring info on that from the post on here from that one guy Jose. Also kept my ABS, and luckily all the wiring for that is separate from the PCM. I cut out all the wires I didn’t need from the stock connectors and separated what I did. Then I opened up the whole stock harness and pulled out all the unused wires. Wrapped up everything in cloth tape. Made a new harness for the fuel pump, since the new harness had its own fuel pump relay. I used the stock fan relays and wiring by using the signal wire off the stock PCM. I went with a new harness for the engine to keep it simple. Didn’t want to drill into firewall so I put the LS PCM in the stock location and fuse box not too far away from it. Could’ve done a better job at hiding all the wires, but I was in a rush to get it running. And to keep it simple for all you b body guys, this is what I used from the stock PCM. Keep in mind this is for a 95 so I don’t have a tach signal to save off the PCM:
Red connector
Pin 10 - sec fan DK BLU
Pin 11 - prim fan DK GRN
(Ground signals for relay)
Black connector
Pin 1 - A/C request signal DK BLU
Pin 8 - VSS speed
Pin 21 - A/C clutch status DK GRN
Clear/Gray connector
Pin 14 - brake switch PPL
Pin 15 - park neutral signal org/black (optional)
Blue connector
Pin 3 - PCM ign feed PNK
Pin 8 - A/C clutch control DK GRN/WHITE
Pin 9 - Check engine light
Pin 12 - A/C refrigerant pressure sensor RED/BLACK
Red connector
Black connector
Pin 8 - VSS speed
Blue connector
