Okay, I'm trying to fix the damned oil leak from my last Opti install in our 95 9C1. Using Fel Pro gasket set. The directions say:
FIT
Fel-Pro Installation Tips
Distributor Shaft Seal
Install seal into the recessed cavity of the seal retainer or into the cylinder block (depending on engine model).
____________________________________________
IMPORTANT: This (PTFE) seal must be installed DRY.
Do not lubricate seal lip or the sealing surface
Timing Cover Seals
Prior to installing the rotating shaft and/or seal, apply a thin coat of lubricant, such as grease, on the sealing lip and shaft.
Important: Do not install any seal without break-in lubricant protection.
Okay, the directions seem to be conflicting. WTF do I do, and EXACTLY what surfaces need a lubricant, and EXACTLY what surfaces do not? I'm about to put this stupid thing together, and at this point, this will be the last time.
Thanks, and be specific. You can feel free to pretend I know nothing about cars, as apparently, these install directions aren't making sense to me.
So the 'rubber' parts of both seals, the part that actually seals against the opti, and water pump drive, respectively is to be dry? Okay. I'll make them as dry as possible.
Thanks.
FIT
Timing Cover Seals
Gene, feel the surface of the new w/p and opti seals. These are the top 2 seals. They are teflon coated. That's why they have to be installed dry. The crank seal is rubber. It's the lowest seal. That one can be (should be, but some do and some don't) installed wet or coated w/ oil. That should clarify that however the hugest single mistake people make is to improperly install the w/p seal. You have to use a tool/sharpie/socket/something else which will work to get it to NOT fold outward on the shaft as you're sliding it on. If it folds, your efforts are in vain and it'll leak like a sieve once you get it buttoned back up.
