Where do you guys get your anti roll bar from?
I have a Herb Adams bar in the rear, which is supposed to be similar to BMR, and a F-car bar in front. Scott Mueller thought this was the most neutral set up.Hotchkis are he best all around bars for the street. Mostly neutral handling.
The BMR bars are a little too big.
This is a sway / anti-roll bar - it's just mounted to the frame instead of to the control arms. This is a better way of mounting the sway bar.Oh, Im sorry, I was not thinking SWAY bars, but rather this kit in the pictures....
The kit in the picture is not the one on the car, but it is the same thing..... (I think) its NOT MY CAR.
Sorry for the confusion.
ZACH
Doesn't Mike Harris do these?Where do you guys get your anti roll bar from?
Sway bars are not the same as an anti roll bar. What the OP is asking about is a rear end only device that helps keep the car straight and level during the launch in drag racing.I got my Hellwig bars from here: http://www.neverenoughauto.com/index.php?target=categories&category_id=7104
Sway bars = anti-sway bars = anti-roll barsSway bars are not the same as an anti roll bar. What the OP is asking about is a rear end only device that helps keep the car straight and level during the launch in drag racing.
Similiar concept but huge difference. Sway bar is streetable and the anti roll bar would be a track only option.Sway bars = anti-sway bars = anti-roll bars
All different names for the same concept. There are different types of these bars - control arm mounted, frame mounted, etc.
The sway bar will actually twist with the motion of the car but a anti roll bar is basically ties the frame to the rear end and is a solid mount.So your saying there is no articulation on welding it to the frame and a better option would be to weld it to the sway bar. I understand your point but unless you like to drift your car or go fast around corners what is dangerous about it?
Sorry just getting ready to do thiscwm4
