Ok drilled it out. I was trying to clear out the rear drain tubes as well but you can't get to them from the sunroof. I partially dropped my headliner to get access to them but they looked fine and water was draining down them fine. One word thing is that the water camera it of three bottom of the rocker panels under the rear back doors. As if the bottom of the rear drain tubes exit inside the rockets under the door
