Just curious on what you guys found to be the problem, going through the FSM, the O2 sensor is fairly new, Bosch I do believe ( this isn't my car by the way, just one I am working on) Hooked up my scanner and read the O2 volts on the faulty bank, seemed fine for a second at start up, then almost went to zero when blipping the throttle, but would come back up as the RPM's came down, the O2's when holding throttle steady at 2000 RPM read .8 to .9 but this one is reading .1 or lower. I would think that it could be a possible bad O2 sensor, but unsure, figured I would ask what you guys have run into. Thanks
