1 - 12 of 12 Posts
Would like to pass emissions. Anybody have a CC503 laying around?
Figured I'd ask before buying a new one.
Thanks for looking Matt, but I'll hold off. Already taking one step down (from the XFI467), really don't want two steps.
Just curious, is it the 112 or 114LSA?
I have one with the following specs: Cam Shaft, Lift: 0.502"/0.510" @ 1.5:1 Ratio (0.535"/0.544" @ 1.6 Ratio), Duration: 275/281 224/230 @ .050", 114 Lobe Center Line, S/N: E 0837-05 02/21/05 (Based on Comp Cams 07-503-8 Extreme Energy 276HR-12 but with 114 Lobe Center Line) It was ground with 4 degrees of advance for improved lower-end performance when installed "straight-up" with a standard timing chain.
^^^ Sounds real close to what I am looking for. How much do you want for it?^^^
I'll have to check with LE or some other builder to make sure that will meet my goals.
I was thinking $150.
I used it from 2005-2007 when I changed to an AI Cam for 2008 to present.
Thanks!
If my hub puller didn't strip out, it would've been in the motor already too! cwm2
1 - 12 of 12 Posts
