E
I bought one used and it didn't come with them. I looked on line and could only find them in Danish and Swedish. If anybody has a set and can fax or e-mail, that would be terrific. If not, can somebody confirm whether I have to run a separate power wire to hook up to the yellow wire that is part of the IP bus cable and that the black wire that is separate is for a ground? TIA
Erik, what are you connecting it to?
The yellow is 12 volt constant. and yes the black is ground.
E
Thanks! I'm connecting it to a Pioneer DEH-P77DH headunit.
E
TTT Does anybody happen to have this manual? It would be very helpful if you do. Thanks.
Better late than never, according to the pdf at Pioneer's site.
Yellow to 12v
Black to Ground
Plug the IP Bus Cable(s) into both
Use brackets to mount to the car.
Align the angle switching dial horizontal
E
Thanks. I couldn't find the instructions when I looked on their site.
