1 - 12 of 12 Posts
I am installing a lt1 electric water pump. I did not get the plug that goes with it. Do people weld up the hole or am I going to overboard. I just dont want a plug that can leak or come out.
Dan,
I think they're talking about the hole that the spline drive pokes through to drive the mechanical pump.
The best bet without going overboard, would be to put a freeze plug back there, bondovw. This was done when I had my EWP put on at a local speed shop in TX. I don't remember the exact size, but you can call or IM george or angel at George Bates Automotive, they have done this before too.
Yea anyone who can wig weld aluminum can do it. Like dustman said. Mine came with the plug I put it as far as it can go and put solicone and I never had a leak.
Or, you can just leave the waterpump drive in there, it ain't going anywhere, and it isn't going to leak, and you can't really see it.:)
Next time the engine is out, I might pull it.:p
I just put a plug in it. No leaks for about 3 years now. -Josh
if the OP is talking about the hole in back of WP after gutting it for electric
1 1/8" freeze plug.
you can leave the drive gear in motor if you want on EWP swap.
I welded mine, put a 1/4 thick aluminum round plate in the hole and welded it on both side. Weep hole is welded shut that way too.
I leak tested the welding and its fully seal.
My buddy used the freeze plug that came with the meziere with block freeze plug sealant and its holding fine.
Yes, I got it in my head he was talking about the drive in the block. As mentioned above, just get a freeze plug from any auto parts place. Use some perma-gasket, and it goes in from the front.
1 - 12 of 12 Posts
