What MIL code do you think would trigger both radiator fans?My current speculation is that with the call for both fans to run because of the MIL code, it creats a high current draw which somehow cuts out the dash.
There were issues with the digital dash from the factory. In the majority of cases the final solution is to fix the solder cracks on the circuit board.My digital dash also started to cut out on top of it all which added to the confusion.
1995 9C1 Intermittent Dash Display Fix
. After 200,000 miles of trusty service, my speedometer and odometer display would intermittently black out. There have been lots written about this, however, I didn’t see many pics of the failure mode for the 94/95 model years. The speedo is an easy part to access; takes about ten minutes to...
