·There has been a problem with the bushings that came from an early batch of BMR control arms. I purchased my set in summer of 2001. The problem is that the bushings are desinegrating. All 4 ends of my LCA bushings were split and/or 1/2 worn away. I haven't checked the uppers yet.
My symptoms was that the read end was shifting during hard acceleration and deceleration. My original bushings were RED and showed signs of spliting on one side. Upon removal, they all had split.
The Cause: Bushings were not cured correctly and with the weight of our B-Body's, they were going bad more frequently than other platforms. The replacement bushings are BLACK but I'm not sure if all RED bushings are bad though.
The Fix: Call Frank at BMR and he'll send you a set of bushings to replace at no charge. He'll send you 12 bushings - 2 per each end (less the axle bushings). You MUST save and reuse the metal sleeve from the original.
If you have any questions or you might be affected, Call Frank. You can find his number on his website.
