I'm thinking about buying a 3.42 gearset out of a gn and want to check before I buy it to make sure you have a reluctor that fits. What diameter does the pinion shank need to be? Thanks a lot!
Are you able to make them? I wont buy the gearset if I know I can't get the right reluctor.
and what about your other type of reluctor? is that a possibility?
good news
farther searching came up with 8 gm oem 3:42 reluctors pn 26018945
$35.00 shipped ground each
mild surface rust but serviceable.
i can make a solid shim style for any gearset for $135.00 shipped ground
replace's crush sleeve for better setup and reuseable
