hey guys, so im looking to install a new head unit in my 91 caprice wagon. im a total newb when it comes to car audio, but my friend has done alot of it and will help me install it. i just wana make sure i get all the right stuff to make it go smoothly. i just want a single din unit with aux in. ive found some cheap on amazon. will any single din unit work? also what instal kit is best? will the one for like 15$ at walmart work?
http://www.walmart.com/ip/Scosche-Gm1504-Dash-Install-Kit-for-1982-2005-GM/14667118
again sorry for the basic questions i just wanna do it right.
Yes, the simple Walmart dash install kit will work. You'll also want to pick up the appropriate wiring connector. You'll wire the harness coming from your new single DIN cd player to the Scosche connector, and plug the Scosche connector into the vehicle wiring harness. This way you don't disturb the factory wiring harness.
I recommend soldering/shrink tubing the connections, not just using the crimp terminals like most people do.
