I current have the old aq 3500 amp with 2 hdc3 12s unboxed and I was wanted to know if that amp was powerful enough to run 3 hdc3s. Most people that ive seen are running 1 aq 2200 on the pair but do you think I should just run the 2 hdc3s or could I run 3. I want to power the woofers adequatly instead of making a mistake of buying a extra woofer only to find out that its being undepowered.
probably not.. depending on what you wire it to...
