I've searched and was not able to find anything. Which wire can i splice into to use the auto dim feature of my headunit. My car is a 94 fleetwood brougham.
I noticed the lights on the climate control change when the headlights come on but I dont know which wire would control that. I think the Cadillac climate control is wired the same as the Roadmaster climate control if that helps.
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink (if available) Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Thanks i'll take a look at this tomorow, Would these wires be in the trunk though? Or in the small connector that was plugged into the headunit in the dash?
For anyone wondering I ended up splicing into the ash tray light power wire and its works great.
