I guess the only caveat is with the canuck springs they were used already so I'm not sure if it was fatigued a bit and is shorter than it would be completely brand new. The hotchkis and moog springs are completely fresh.
And why was I saying 89008
So I've read a few threads saying that the 80098/7268s are 1/2-3/4 shorter than stock impala height, what is stock impala height?
Ideally if the springs get me to 27" from fender to ground that'd be perfect, any higher than we run into issues with the rear since it's at a 27" from top of the wheel well to ground to which I'd have 3 routes of addressing it,
- finding a taller spring for the rear to match the new front height,
- pop in a spacer in the rear to match the new front height,
- or trim the front spring to match the rear (not a fan of trimming)
I'm running stock 255/50/17s. The main difference between a stock car is my wheels are centered with extended control arms moving it back 3/8s, and I had the spring perch moved up by the same amount so the spring wasn't at a gnarly angle which shifted the height of the perch causing the rear to sit higher, if I didn't do that my ride height at this point in time would have been even back and front.
The story behind moving the perch forward was cause of how the spring sat after I centered the axle, no way I was running at this angle, and that was with a spacer. But yea eventually switched over to the hotchkis which I guess is tall enough where it's not as screwed up.
My previous front heights with the canucks were 26 inches and the hotchkis was around 26.5. The canuck spring was pretty much on the bump stop so that may not even be the actual height the spring was providing.
So my car has the butt up face down effect. Which looks great but when your hard braking and turning the car is dive bombing hard especially with the softer spring up front.
So if the 80089s get me to 27" up front, we'll be good 😪.
Hopefully have them in by tomorrow.
