·Howdy folks, i just got me 4 autospecility smooth rotors and from what I understand they come with studs too short for the impala alloys. So I also got 4 sets of the ARP M12x1.5 thread wheel studs.
I've never removed/installed wheel studs before so let me know if there is anything you guys would do differently.
Removal Process = putting a lugnut on the stud and pound them out with a big hammer
Install Process = Pull them through by putting a lugnut on the threaded portion and tighening the lugnut, the lugnut will have a big washer between it and the rotor. Said washer will ofcourse be removed once the stud is installed...just want to prevent the lug from being imbedded into the rotor
So for those of you who have done this did you have to remove the ABS ring?
Thanks!
Thanks!
