O
I know that my factory cd player has a button on the front that says "aux" right under "cd"
is there a jack in the back that i can plug my sirius receiver into? or do I need to buy an adaptor that goes into the cd changer plug? and is there such a thing made?
thanks in advance...
R
The cd changer plug is most likely proprietary. So it's up to your manufacturer whether or not there is an adaptor for inputs through the cd changer plug.
There should be a set of aux inputs (most likely rca) in the back your reciever. That's what I'd use for your sirius.
1
The factory unit is going to require an adapter which is going to run you around 75-90 bucks so heres where you make the decesion keep factory or go aftermarket. I suggest Aftermarket.
R
oops... I totally missed that the radio was "factory". You will not have rca plugs in the back of the factory unit iirc.
Like mcginnis says.. get an aftermarket unit especially if you're gonna spend money on sirius or an adaptor.
