Hello! Does anyone have a stock 95 B4U Caprice .bin file? Or is there a way to read the .bin file on my 96 PCM?
Thanks!
The two are only related functionally. OBD1 & OBD2 are two different systems using two different filetypes requiring two different types of utilities to interact with them.
What works for OBD1 does NOT work for OBD2.
V92 = B4U
(The only difference between a V92 and a non-V92 2.93 calibration, is a single flag.)
There is not a B4U here but there is SS, 9C1, caddy, and wagon files. Not hard to change gear ratios. I have never loaded one of these to a PCM but I have spent a lot of time comparing tables.
Careful with these bins... I was a bit surprised to find a Caprice SS tune with a 6300RPM limiter.
Check everything before you run em!!!
