Can someone please tell me which front pads and rotors fit a 94 Caprice with the LT1 and B4U tow package? I have been searching, googling, reading and emailing until I can't see straight.... I am so confused and frustrated! A friend told me he is running Powerstop z23 pad and rotors out but according to their site this won't fit my car.
Will brake parts for the SS fit?
If you are NOT going to upgrade your brake calipers (not strictly needed), use the '7492-D614' front pad spec used by the 93 Caprice 9C1 and the 94-96 WX3 & WX8.
In other words, ask for the brake pads for a 94-96 ImpalaSS, they fit into your civilian Caprice's calipers (same as 93 9C1 calipers) just fine.
Thank you. Do the rotors from a 94-96 SS also fit? Is it necessary to replace the ABS ring when changing rotors or can they be used?
Yes. Every Custom Cruiser, Caprice, RoadMaster, and/or Fleetwood that is NOT a limousine uses the exact same front rotor, including Impalas SS and 9C1s.
If you ask for the front rotors for any of these vehicles (same rotor), the ABS tone ring will already be in place on the new rotor.
Buying drilled rotors is a BAD idea. Our rotors (front AND back) are barely large enough; drilling them removes mass from rotors that already don't have enough mass.
You can also upgrade to the 9C1 calipers and install the thicker pads. I had the opposite happen on one of my 9C1s (a previous owner downgraded to the civvy calipers just on one side!) and I had a surprise when I went to install the OEM 9C1 pads that I had in stock. So I ended up replacing both calipers with the proper 9C1 version. It's always recommended to replace both side brake parts on the same axle at the same time but I guess the previous owner didn't get the memo.
The good news is that after you upgrade, both the civvy pads and the 9C1 pads should fit the bigger caliper because I think the only difference is the spread of the caliper to accommodate the thicker pads. I never tried this upgrade myself on a civvy car. But like I said, I saw the opposite happen, so that tells me the calipers are physically interchangeable if you are interested in using the thicker pads.
As others mentioned, rotors are the same. And they come with the ABS ring.
Thanks for the info. There is so much that it borderlines on being too much
Well then let's narrow it down to two options to save your sanity. I'm not sure if you have 11" drums with your car or not. If you don't have a 9C1, then the drums are usually the only way to tell the difference between HD or not. You might have HD if you have the tow package. If it came with them, who knows if the previous owner has retained the HD front calipers.
Either way, the HD stuff will fit a civvy car... so that's why I'm giving you two options below...
* All from Rock Auto *
Option 1: Just go with the POWER STOP KCOE2936 Stock Replacement Kit. Skip to bearings below.
Option 2: Retain existing configuration or upgrade to HD calipers which will allow you to use thicker pads:
CARDONE 184624HD
CARDONE 184625HD
CENTRIC 90862070 Select Pack Front Rotors and Semi-Metallic pads
Some people prefer ceramic pads these days. I run 9C1 cars and I've always been happy with Semi-Metallic performance (albeit more brake dust and more rotor wear, but good stopping power). If this concerns you, then you will have to pick out rotors and pads separately as I couldn't find a HD kit with ceramic pads (makes sense since Semi-Metallic was OEM on HD cars).
Don't forget bearings and grease, which are the same with both options above. The kits usually don't include these!
A3 x 2
A6 x 2
Seal 4739 x 2
On a 25 year old car, I'd also consider replacing the rubber lines if they haven't been replaced in a long time or if they look dry and cracked.
API 147417668 x 2
(and many others)
Don't forget brake fluid too! And consider a full bleed and fluid change if you haven't done that in a while. So buy at least 1 quart so you can pump all four corners until the fluid runs clean.
Hope this helps. And I hope others chime in if I got something wrong. Good luck!
