Based on advice from friends, it looks like this engine will be coming out for the cam install. Since I am also replacing the trans, I have been convinced it is less work this way. The silver lining is that I get to paint the engine.
Yes please....
Anybody want an OEM Fleetwood air compressor assembly?
Caddy, you have some unique problems with your cooling requirements. Here in Oklahoma the weather is not as extreme. (Usually) You may want to consider something like this.As far as porting the oil pump, I am clueless. I also don't own a Dremel. Maybe that is something I will do to the engine that I will be building on the side.
The "oil cooler" I deleted turned out to be full of trans fluid. I didn't pay attention to the lines, I just assumed it was an oil cooler. I've included a picture below. Is this cooler factory? Or is it from a 9c1/ss? It is run inline with the radiator cooler. The only oil cooler on this car is the one in the radiator.
As far as preventing fluid from getting too cold... I did spend some time thinking about that. In this part of the country, it gets brutally cold (like -30*F without the wind chill recently). I have had problems with both my trans fluid and power steering fluid freezing. It makes it very difficult to drive the car first thing in the morning after sitting. Running either of these fluids through the radiator may have some benefit in such conditions... But, my concern is I may be trading some performance on the track, when trans and power steering fluid are being pushed to the limit thermally.
Caddy, You're right on the cooler placement. I had it saved on my old computer but I had a "senior moment". I did a quick check and found this. Transmission Cooler Installation | How To Install A Transmission Cooler Just remember that the top fitting on the transmission is the return. My plan is to run -6 AN lines to the frame and then run 3/8th stainless steel lines the rest of the way. I have one of those manifolds that I referenced to control the fan.As of now, I plan to use the factory trans cooler for my power steering, and the external Hayden for the trans. Both will be plumbed independently. With the factory setup, the trans fluid goes through the radiator first, and then the external cooler.
I wonder if there is some kind of block/accessory heater I could use for the extreme cold days? I shall Google.
The "top coat" of the underside will be rubberized undercoating, like I used in the trunk area.Just wondering what color you intend to paint the underside.
