Possible for the vss to be bad but speedometer working?
1-2 shift delayed,if you get car up to approx 18-20 mph & let all the way off the throttle it shifts,also driving along 20-30 mph,then turn a corner(where you would maybe slow down to 15 or so mph)instead of staying in 2nd the car goes back to 1st & you have to do the 18-20 mph let off again thing to shift.
It has new fluid/filter & i pulled the accumulator,spring wasn't broken,piston seemed to move ok w/out cocking & housing wasn't scored.
Check your TPS. I would set it to .72. Most people recommend .67 but I was getting a TPS too low code and the car was shifting like yours
I was going to say TPS as well. I had an issue like this with a 98 GMC Jimmy. Shifted real late and hard, and when you let off the gas, it shifted back.
This thread caught my attention because my 95 6 speed is slow to come back to idle sometimes and was kinda thinking VSS. I can be stopped and it will be turning 14-1500 rpm until it finally works its way down.
Might just need a good TB cleaning.
I had already tried a different tps,i had a roadmaster that the body had some dings on,so i just pulled the tranny out of it & ins in this car yesterday,hated to take the rm apart.Between my son & i we have 4 wagons 3 w/probs,unfortanately the rm was the best runner,but also the ugliest,so i'll use it to fix the other 3 cars.
