L
How much grease should seep out of the ball joint jacket? I've got a little on one side and a lot on the other. Was someone just a little too enthusiastic with the grease gun or should I be concerned?
Thanks,
T
Hard to say from this distance. Clean up the grease and see if you can see any damage to the boot. Also watch for additional grease seepage. If the boot is bad, it is replacement time. I am not sure if the boots are available separately. They might be from street rod shops for folks who want to color coordinate their suspension pieces.
Terry
Boots are available separately in the "Help" section of car parts store. If it is the boot make everything if fairly clean.
