I replaced the upper and lower ball joints on Saturday. Man what a difference! I guess my old ones were really worn out.
Anyway, the front of my car sits a smidgen higher than before. Do the Moog ball joints raise the car or does the front sag with worn ball joints? (or both)
Mike
A
Neither, most likely. Rather, it's probably just your springs need to re-settle after being unloaded for the balljoints replacement.
In other words, drive it a week and check back :D
I'm about due for new balljoints myself. Only about 45K or so on these, but to say they've been rough miles would be an understatement :D . Would much rather replace them "now" instead of "later, after the damage is done to the fender from failure".
My ball joints were original with almost 90,000 miles. They started popping a while back so I knew I they needed replaced. I also developed a loose feeling in my steering and thought I need to tighten up the steering box and the car wandered around a bit.
The new ball joint made the front end feel 100% better. The car doesn’t wander around and the steering feels much tighter (no dead spot). I must have been slapping around those old ball joints for a while. I definitely got my moneys worth on those things!
BTW, changing lower ball joints on the car is a royal pain in the butt!
The uppers were a piece of cake.
I will have to take some measures to help settle my front springs…all for the sake of maintenance of course. :D
Mike
