My bass tends to shut down after awhile of playing and all I have is my highs playing..any suggestions??
Or you have a poor ground, I would check there too. I had a similar problem, and the ground was very weak, and after cleaning it and snugging it up, never had the problem again.
my guess is the amps going into protection as well
I would try everthing they said. Also check remote wire and if it is getting hot and going into protect that is a good sign you have a wiring problem. Either power or ground wire is too small or have a bad connection somewhere.
if the amp is in the trunk then ur car dosent have to sit in the sun long in the summer heat to go into protect, my amp is in the trunk on top of my box, if i dont park in the shade then my amp goes into protect, planing on cuttin rear deck soon to provide some type of airflow
