·I just talked to Mitch Drouillard at Be Cool about making some radiators that will be a drop in fit the 94-96 Impala SS. The only thing you should have to do is cut the upper and lower rubber supports to accomidate it because it will be a thicker dual core design. I've talked to some SS owners and found out that the ones Be Cool lists on their site are not exact replacements. For one, the fan mounts are incorrect. As it turns out, they are about a 1/2" off from stock. Mitch stated he would be willing to correct this. The other problem is the tranny/oil cooler tank connections. The Be Cool connections are samller than the stock 5/8" inverted flare connections on the SS. Mitch said adaptors would be provided with the new radiator so the stock hoses could be used.
The cost has not been finalized, but it will be in the $500 range for this one with the tranny cooler only:
62065 Detail
And $600 range for the engine oil & tranny cooler design:
66065 Detail
Now I know this might be a sore subject for some of you, but I personally am still looking for a better radiator that will work with my stock fans and allow me to ditch the external coolers I'm running for my engine oil & tranny fluid. I'd also like to do this now so I don't have to worry about overheating come summer time. The plan is to get this order together by the end January and all will be shipped from Be Cool in Essexville, Michigan with the cost of shipping possibly being thrown in if we get 15 orders total (both styles combined).
p.s. If you don't want one or don't like it, please keep your comments to yourself.
62065 Detail
66065 Detail
