Anyone else having issues with the belt tensioners above 6K? I am shifting the new combo at 6400 and eating belt tensioner bearings after 8 to 12 runs. Belt is in alignment with a factory length belt. I have no ac so the the ac bypass pulley is spinning in place of the comp. Anyone running without the belt when making a pass?
When you're talking operation north of 6K, you should be asking in the performance section above. That's a different world than the normal maintenance section. BTW - what times are you getting with that setup?
